New (and hopefully final) engine build.
Old May 5, 2023 | 01:04 PM
  #41
dswilly's Avatar
How do you like the glowshift oil cooler adaptor? I have a stock oil cooler and think about installing it using that.
Old May 5, 2023 | 03:32 PM
  #42
Discorama's Avatar
I retrofitted my D2 with an oil cooler and use the Earl's sandwich adapter, which comes with an integrated thermostat. It brought oil temperatures down up to 20 degrees F.
Old May 5, 2023 | 03:43 PM
  #43
Tony Luna's Avatar
I’ve never checked the oil temp. I did fit a 2002 oil cooler. The sandwich adapter is for the mechanical oil pressure gauge I installed.
Old May 5, 2023 | 03:52 PM
  #44
Discorama's Avatar
Did you use the ports on the front cover to attach the cooler lines? I tried that first and it didn't work because my front cover doesn't allow flow through these ports.
Old May 5, 2023 | 04:20 PM
  #45
Tony Luna's Avatar
Yes. I got the lines with the cooler. Connected right up to the ports on the front cover.
Old May 5, 2023 | 10:35 PM
  #46
Discorama's Avatar
Has your front cover two oil pressure relief valves? Otherwise there isn't much oil flow through the cooler.
https://landroverforums.com/forum/di...f-valve-86314/
Old May 23, 2023 | 05:38 PM
  #47
Tony Luna's Avatar
After ordering a new tensioner, followed by a new balancer pulley, finally took her for a shakedown run.
Runs smooth and strong. No strange noises or leaks - only been 45 miles…
Surprised it all came together. New motor, rebuilt steering box and new PS lines, new shocks, springs, and all suspension bushes.
Hopefully she stays running longer this time!!!
Old May 23, 2023 | 07:07 PM
  #48
Extinct's Avatar
Looks really good!
Old May 23, 2023 | 07:21 PM
  #49
Discorama's Avatar
Wow, that looks like brand new.
Old May 24, 2023 | 06:06 AM
  #50
mln01's Avatar
That shur is purty!
