New Member -- New potential Disco!
Old Feb 13, 2018 | 11:15 AM
  #41
Saturnine's Avatar
Hmm.. Not a bad idea. Truck has less than 100k
Old Feb 13, 2018 | 11:44 AM
  #42
CollieRover's Avatar
A good set of metric 1/2” or 3/8” socket and wrench set, a do it all screwdriver you can swap different heads out of should be good. Maybe a breaker bar. Triple A Gold Membership just in case.
You may want to bring along a new thermostat Genuine, but things like belts, sensors can be had at Napa or other stores. A new set of good wipers would not be a bad idea either.
Convert it to Rotella 5w-40 for the drive with a K&N 3001, but the other fluids last 20k to 40k so just make sure they are topped off and not completely shot.
Have a good time and Congratulations!
Old Feb 13, 2018 | 12:09 PM
  #43
Saturnine's Avatar
Thanks for the tips.. Tstat should be here before i leave hopefully.
Old Feb 13, 2018 | 12:15 PM
  #44
Dave03S's Avatar
If you plan to swap the stat out before you drive, make sure you know how to bleed the cooling system completely. Not that difficult but often overlooked.
Old Feb 13, 2018 | 12:24 PM
  #45
Saturnine's Avatar
Probably won't swap it out before we drive since its winter, so should be ok getting home -- but just going to bring it along just in case.
Old Feb 14, 2018 | 03:07 AM
  #46
The Deputy's Avatar
I'd be sure to ask about, or check, the transfer case fluid, both of ours were empty, or nearly empty after purchase. I believe this is one of the most overlooked fluid changes on these rigs.
Brian.
Old Feb 14, 2018 | 07:14 AM
  #47
Brian.
mainly because checking it is a pain in the neck, and they leak like crazy. And you will need a 1/2” breaker bar to do this, a 1/2” Socket wrench not a bad idea either. I use the pump type filler that fits right on the heat oil bottle, and it works great.
Old Feb 14, 2018 | 07:28 AM
  #48
Saturnine's Avatar
Cool, thanks for that -- Tools will be purchased as mentioned so adding breaker bar to the list. Ugh. I wish i could fly with some of my tools but.. Trying to do the carry on thing but we'll see
Old Feb 15, 2018 | 06:32 AM
  #49
Harbor Freight is your friend. I have had good luck with their impact sockets, and socket wrenches. The filler plug for the Transfer case is concealed by a cable. A 1/2” socket with as small a head as possible is a good idea. Also, maybe a small length of pipe to add to the end of a 1/2” socket instead of breaker bar could work well.
then buy a bag to keep the tools in, in the back. I keep a few specific tools in one for long trips. You never know if you may have to change a headlight bulb, or other ancillaries.
Old Feb 15, 2018 | 09:26 AM
  #50
Saturnine's Avatar
HF's have been googled a little while back, thats where i was planning on hitting first for tools and then Walmart for fluids.
Welp, my copilot bailed on me so looks like i'll be doing this trip solo which should be.. Humbling
Eeny, meeny, miny, moe..
