New Oil Gauge Installed
Old May 16, 2012 | 09:03 PM
ralphobell's Avatar
Originally Posted by DonRW2007
Unfortunately, with my aging eyesight I need a gauge with a big honkin' dial to keep an eye on pressure, temps, etc.!
Don we all know Bigger is Better, especially here in TEXAS!
Old May 16, 2012 | 09:15 PM
How big is the unit in total?
It fits inside your ashtray but how does it compare to a pack of smokes?
Whos wire harness did you use?
Glowshifts or theirs?
Old May 16, 2012 | 10:05 PM
ralphobell's Avatar
Spike the unit is smaller than a pack of smokes. It came with a 1 meter wiring harness and sending unit.
Here are the dimensions of the unit.
24 x 48 x 75mm (1/32 DIN) or roughly 3/4 (H) x 1 7/8 (W) x 3 inches (L)
Old May 16, 2012 | 10:11 PM
ralphobell's Avatar
I like this guys setup over at overland-rovers.com He has turned his Disco into a freaking RV.
Old May 17, 2012 | 09:25 PM
That is nice.
I have one of those clocks too, I'm saving it for when mine goes bad.
He put the gauges where the cup holder was and different colors for different things, very nice.
Old May 18, 2012 | 07:00 AM
slanginsanjuan's Avatar
I purchased my Disco in December of 2010 and it had 70K on it. From what I can tell it looks like the Head Gaskets have been replaced. It now has 106K on it. Only thing I have done to the truck is the 100K service and changed the rocker cover gaskets.
I had been using the standard oil filter and Mobil 1 5w30 synthetic.
I don't have any oil pressure readings from that setup.
My current readings are with 5w40 Rotella T6 synthetic and a Mobil 1 301 filter.
The truck has alway run a synthetic or synthetic blind. I have receipt from the PO showing the dealer using Castrol 20w50 synthetic blend.
The reason I switched to Rotella was due to when I change the rocker covers the inside wasn't bad but nowhere as clean as Street Wolfs. This thread shows my rockers.
https://landroverforums.com/forum/di...ounting-48682/
Not as clean as Wolf's but oh so much cleaner than Slang's.....
Old May 18, 2012 | 07:08 AM
that is cool.
-what's he monitoring...indoor and outdoor temps there? i can't make anything of those numbers except that blue is a warning color.
-funny he went high tech and then put the classic clock in.
Old May 20, 2012 | 03:14 PM
ralphobell's Avatar
Hi is in Europe so those numbers will be in Celsius. Not sure what he was all monitoring.
ftby55
Apr 24, 2014 07:58 PM
Discolife
Nov 23, 2011 07:58 PM
seamonkey1
Mar 29, 2011 08:50 PM
lipadj46
Oct 17, 2010 06:34 PM
jycsalas
Mar 19, 2009 07:42 AM
