New owner - used 2002 Disco
Old Oct 18, 2008 | 07:43 PM
dholland's Avatar
Default New owner - used 2002 Disco
Hi all,
I am new here just got my '02 Disco today. It has 80k on it. Seems to be a nice vehicle.
A couple of things that I need to check into:
1 - When I use the button for my power locks...only the back passenger side lock does anything. The other 3 doors and rear door do not lock or unlock.
2 - I have the 3 Amigo's lit up....I have read where this could possibly be just brake dust. I have not tried cleaning it yet.
3 - My key. When I go to turn the vehicle off seems to get stuck in the position before the off position, I have to turn it back and forth a couple of times before I can get it to the position to release my key.
4 - What kind of realistic gas mileage can I expect? I will not be going off road. Just everyday driving
There may be a couple more things, but I cannot think of them right now.
Any help will be greatly appreciated.
Thanks!
Old Oct 18, 2008 | 07:57 PM
Default RE: New owner - used 2002 Disco
1-your door lock actuators are bad, common problem on LR's. www.roverlandparts.com
2-do a search on this forum for that fix.
3-pop the trim piece off of the shifter ****, tighten the nut that is in there, see if that helps. (its not going all the way into park)
4-you MUST use premium gas, 12-14 city 16-18 expressway. That is realalistic MPG.
Old Oct 19, 2008 | 08:09 PM
dholland's Avatar
ORIGINAL: Spike555
I have removed the plastic piece. Where is this nut at? I have found 3 nuts that seem to be part of a mounting bracket. Anywhere I can find a picture of what I need to tighten?
Thanks,
DH
Old Oct 19, 2008 | 08:36 PM
There should only be one nut in the middle of the shifter ****. It would be the middle nut if there is more than one.
Old Oct 19, 2008 | 08:55 PM
dholland's Avatar
Thanks Spike...I am pretty sure I know what you are talking about. I will post and let you know. Will probably be mid-week before I get to do anything
Old Oct 19, 2008 | 09:46 PM
hazletbassist89's Avatar
just so you know, if it hasn't all ready been done, you need to have the front driveshaft rebuilt asap with greasable U joints. If you don't it put a few aerodynamic holes in your transmission. Shouldn't cost more than $300. Welcome to the club
Old Oct 19, 2008 | 10:17 PM
ORIGINAL: hazletbassist89
What he said.
innzane
Feb 26, 2012 08:25 AM
ChefGabe
Dec 27, 2011 09:04 PM
TREX_Star
Dec 6, 2007 10:27 AM
gmutis
Jun 30, 2006 07:45 PM
tdiddy
Feb 11, 2006 02:21 AM
