New plugs, wires, coils - still misfire #4 & 8
Old Apr 29, 2012 | 12:37 PM
pdowning6's Avatar
Default New plugs, wires, coils - still misfire #4 & 8
'04 Disco is misfiring in cylinders 4 & 8. Changed plugs, wires & coil packs. What would be my next test? I am getting spark. Wondering if I need a head gasket but don't know a surefire way to tell. Any help is appreciated.
Thanks,
Pat
Old Apr 29, 2012 | 09:17 PM
Only 2 other things that can cause a misfire, burned/chipped/carboned valves or head gasket and there are tests for both.
Old Apr 29, 2012 | 10:21 PM
Discovery SE7's Avatar
You've covered the internal engine, now you're left with the internal engine. The next easiest thing to do is probably a compression test. I would suggest testing all of the cylinders on that side (2 and 4 are both on the passenger side). Low compression in a cylinder can cause a misfire. Compression loss can be caused by either valve or the piston rings. If you are having a problem with a ring, you will usually see oil on the plugs or evidence of oil being burnt by the plug when you pull it.
You can get a compression tester for like $20-40 and takes about 15 mins to do four cylinders.
Old Apr 30, 2012 | 03:59 AM
And there is this Buy Tracer Products Coolant/Auto Body Dy TRATP39000008 at Advance Auto Parts
a coolant dye, after running truck and engine cools remove suspect plugs, look for flecks of dye on plugs....
Old Apr 30, 2012 | 06:57 AM
pdowning6's Avatar
Thanks, I will start with the compression test and see what I come up with.
Old Apr 30, 2012 | 08:38 AM
Also, if the compression test does not show well for those 2 cylinders, then do a leak down to verify burned valves.
There could also be an issue with a couple cam lobes, push rods or rocker arms having wear.
Let us know what you find.
schmiggity
Apr 6, 2014 10:59 AM
00rove
Mar 6, 2012 07:10 AM
rohnbarrow
Aug 24, 2011 10:35 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Rover5150
Feb 21, 2008 10:21 AM
