new rear shock mount location?
so,I cleaned my bent shock mount of the muck and now am looking to fab up some new mounts. I'd like to get them up a bit and protect them a little. not sure if a higher mount, in reference to the axle, will affect the efficiency. (i not that smart, but it seems, to me, it would be the okay)
is anyone familiar with a relocated set up, to keep'em up off the ground? or do I just need to beef up my junk and stick with the dropped location?
I too hate how low the shocks hang and I always thought that they would be easy to knock off. Thanks for proving my thoughts correct
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Could you not just raise the lower shock mount and then get a shorter shock? It can't be that simple
I've seen these shocks by MetalCloak that might solve your problem. They are a Compact Long travel Shocks. MetalCloak 6Pak Long Travel Compact Shock Technology (Patent Pending)
![](http://cdn3.volusion.com/gxsx2.4xnou/v/vspfiles/photos/7023-2.jpg?1395144347)
What kind of welder do you use? I've been looking into getting one but I'm not sure if I need to fork out the big bucks for a name brand or if a cheaper HF or northern tools one will work for the smaller amount of fab work I have planned.
