new rear shock mount location?
Old Apr 4, 2014 | 01:29 PM
  #41
dusty1's Avatar
yep,so which of you guys is whipping up custom castor plans?
Old Apr 4, 2014 | 07:43 PM
  #42
OffroadFrance's Avatar
Originally Posted by dusty1
compressed eye to eye =13"
extended eye to eye=25"
for the 12", $800 for the pair
but is 13" compact enough? I will check it out.
Mere peanuts to a hi roller like you Dusty . Is it possible to heighten the top mount into a tower arrangement? thereby then lift the bottom mount and possibly continue with the same shockers. I'll take a look at my truck tomorrow and see if I have any more stupid or idiotic ideas - not that it may help much
There is always the possibility to mount along the radius link and the shock inclined forwards and the further forward you mount them the shorter the shocks needed. The only issue is the stock radius link isn't designed for those extra point loads and the radius link would have a far greater bending moment.
Old Apr 4, 2014 | 08:44 PM
  #43
dusty1's Avatar
France, that was my initial idea. Top axle, inside spring... As on front. Great minds, right. I still can not find a major draw back, save the fact that the tower would need be partially incorporated into the cargo cabin area. But that does not deter me from the idea. I am concerned that it would be a subtraction from articulation, I just don't see how...?
Old Apr 4, 2014 | 08:51 PM
  #44
dusty1's Avatar
And peanuts for a high roller.... Ha. I dug out my trusty old kneepads so I can gather coin for this one
Old Apr 5, 2014 | 09:53 AM
  #45
dusty1's Avatar
anyone know on the sg 3 link EDIT= nevermind, i figured it out
Old Apr 5, 2014 | 10:07 AM
  #46
ZGPhoto's Avatar
Deadly I'm told, great on the trails though. Here's a photo of a SG 3 link on a RRC.
Old Apr 5, 2014 | 10:16 AM
  #47
dusty1's Avatar
that is nice^^... my thinking and continued research on front links is............ 4 link on rear would be pretty easy to figure/fit. but with custom arms on front..would the front then be controlling/limiting the articulation on the rear, even though the rear has greater potential? or would the arms allow enough articulation?
Old Apr 5, 2014 | 10:33 AM
  #48
ZGPhoto's Avatar
At a certain point, yes, but not generally. If there's a hole, your axle will be able to drop into it regardless of front suspension. But in a situation like a RTI ramp yes the front will be important for the rear links to work as seen here.
Old Apr 5, 2014 | 10:42 AM
  #49
dusty1's Avatar
yikes. those are ifs, too, right?
Old Apr 5, 2014 | 10:51 AM
  #50
dusty1's Avatar
so...lengthened, 6deg corrected arms with ballistic joints would get me there? that simple?
