New rock sliders are installed!
"I started with an 1/4 inch hole and worked my way up to 7/16 jumping every 3 or so size bits. I had to drill from both the outside and from the underside and I used an old right angle Milwaukee drill that is about 30 years old but still works great."
Mike, I haven't seen any yet that use the factory holes, not even the unit from RTE. I'd be a lot more likely to install if they used the factory holes, so if you know of a manufacturer that uses them please let me know.
Im in the UK, so I doubt you would order a set from over here due to shipping, but someone over there must do a similar design??
I am very happy with the sliders Nate provided for me. The were easy to install using only a hydraulic floor jack. I have an Milwaukee right angle 1/2 drill (almost an antique as it is all aluminum and must be 30 years old) that made drilling the new holes a cinch. I chose to drill the rear hole first and then moved to the front, that way the sill was in place for all the other holes. Unless you have a step up drill bit you need to start with a 1/4 or so and work your way up. I used some machine oil to keep the bit from dulling and overheating. When I was done I dropped the sill and cleaned the holes with some Brake cleaner solvent and then sprayed some black Rustoleum paint. Then I reinstalled the sills protectors. That being said, there is probably a low corrosion factor because the car's sill material is thick enough and with the sill guard in place and the bolts tightly fixed in place there is little room for water to accumulate. Unless you drive in salt water or heavily salted roads in winter I can't see why the car would rust in these holes anymore then elsewhere underneath. Nate puts a slightly textured coating on before the black paint so they are pretty much slip proof too.
I would also add that the sills act as a running board and even my short wife has not complained that it is any harder to get in then when we had the factory running boards.
do these sliders stick out beyond the door panels?
i'm asking because I was on slick trails this weekend that posed potential for body damage because of small trees along the trail.
would these sliders protect the doors from trees? or just ground level obstacles?
if sliders wont protect from trees, are there any other solutions?
Take Care,
-Nate
WNYErikDiscoII
Dec 20, 2013 03:55 PM
Blakesrover
Feb 20, 2013 10:31 PM
