New Rough Idle
Old Oct 31, 2012 | 10:11 PM
jfall's Avatar
The MAF is a hot wire.
And you are spraying sensor cleaner that is out of a compressed bottle.
The expansion of the compressed gasses cools down the MAF cleaner.
Probably a huge temp differential.
I only spray my MAF with the engine off with CRC Sensor Cleaner.
In my younger days - I have sprayed BMW and Saab MAF's with
Amsoil Power Foam.
Did not kill those MAF's.
Old Oct 31, 2012 | 11:03 PM
lilherc's Avatar
Well guys still stumped and some codes finally popped up. P0154, P0135, P0155, P0130. Will a bad MAF cause these. Remember I just put new Bosch O2's in and cleaned all connections.
Old Nov 1, 2012 | 12:22 AM
But the codes you are getting refer to O2 bad connections, like heater circuit. See attached pages from Bosch manual. May want to recheck those connections carefully.
File Type: pdf
Old Nov 1, 2012 | 11:54 AM
lilherc's Avatar
I will check today. But will these codes cause the rough idle. Any if I have to replace connectors can I just hard wire them.
dillhole
Feb 20, 2020 02:30 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
Willie00d2
Nov 18, 2011 11:26 PM
tsuami1
Jan 26, 2011 10:21 AM
Rover5150
Feb 21, 2008 10:21 AM
