New sound
Old 09-21-2015 | 10:59 PM
redrover75's Avatar
Default Update
I was fairly sure it was the ac. Noise changed when i turned it on, although could not correlate with disconnecting the plug.
So i sprayed the alternator pulley with grease and it momentarily silenced it. I think that pulley is my culpurate. I pulled the belt off again and there is no play anywhere.
Does anyone know the bearing size of the pulley? I am going to have autozone load test the alternator and assuming it performs fine just replace the bearing. Unless people have other suggestions.
Thanks again.
Old 09-21-2015 | 11:01 PM
redrover75's Avatar
Originally Posted by toofaroffroad
for the hell of it, check your Fuel purge valve. I thought the worst when I first heard the ticking, finally found the source and $25.00 later, it's gone.
How would you check it? Just buy a new one? I have been getting the p1415 lately.
Old 09-22-2015 | 07:12 AM
drowssap's Avatar
if you hit the econ button it will disable the ac clutch and make it an idler. that way you can decide if the noise is the pulley or internal to the compressor
Old 09-22-2015 | 07:29 AM
OffroadFrance's Avatar
X1 ............... yep, it effectively disengages the A/C clutch. The pulley runs on separate bearings to the compressor.
Old 09-22-2015 | 11:12 AM
toofaroffroad's Avatar
Default Fuel Purge Valve
Well it sounds like the purge valve is not your problem but if that little things was the ticking culprit you'd know it by putting your hand around it and hearing a muffled ticking sounds and you'd also feel the pulse of the ticking.
jhewitt1111
01-20-2011 07:33 PM
mvjimenez
06-12-2010 10:25 AM
Camdisco24
12-28-2008 10:15 PM
Mountainman
Defender
04-14-2007 03:24 PM
BuffaloRider
10-21-2006 10:23 AM
Quick Reply: New sound
