New style thermostat mod
Old Jan 30, 2017 | 06:01 PM
  #21
Luckyjayb's Avatar
This is how I think they are getting that thermostat to work
Joe's inline thermostat mod upper
Old Jan 30, 2017 | 06:07 PM
  #22
Luckyjayb's Avatar
Based on the pictures about that I posted, I think I've figured how they are getting the intake style thermostat to work. I think the are routing the hose directly over the shroud that protects the pulley and belt for the a/c compressor and ace pump. Instead of doing the inline mod like I posted of joe's they went straight to the source instead of routing it back over the fan shroud. I don't have the ace system so that's a plus for me and I'm still waiting to hear back (like I said they open Tuesday U.K. Time) but I think I can route it over the a/c compressor since the shroud is sturdy then elbow it Dow where the ace pump would be and do a direct shot to the radiator that way and still be able to have a bleed valve. If not depending on the clearance, maybe entirely over the shroud and to the radiator that way and get some of that protective wrap for it so it would transfer heat to the shroud or bonnet blanket. That's just my thouughts so far but still interested what they have to say and if possibly they have diagrams
Old Jan 30, 2017 | 08:21 PM
  #23
Best4x4's Avatar
I've looked at all the clearances available and even if you were to sandwich in their adapter and retain the OEM Tube it would then be out to far and hit the fan blade.
What we need is the adapter plate that attaches to the intake, then a newly designed tube to put the tube in the exact factory location. Then you could rotate the radiator hose enough to install a 45 vs a 90 and connect it up to the factory setup and then just run a new lower hose and call it a day.
You want it to be as rigid as possible like the OEM setup because the clearance between the Alternator & A/C Compressor is extremely close and I fear just a rubber hose on it's own would possibly slap around off road and get damaged by the serpentine belt, Alternator Pulley, or A/C Clutch.
Old Jan 30, 2017 | 08:52 PM
  #24
chubbs878's Avatar
The hood won't close with the hose going over the AC guard. The hose would run inbetween the AC and upper radiator cowling. It may take trial& error with several different routings just as was done initially with the inline housing setup. Perfection doesn't happen all at once.
Old Jan 30, 2017 | 08:56 PM
  #25
chubbs878's Avatar
I could see a combo of silicon hose and steel being used here. What's the best metal to use in a cooling system consisting of the green ethylene glycol antifreeze? Probably 1.25 or 1.5-inch aluminum tube just to keep it consistent.
Old Jan 30, 2017 | 08:58 PM
  #26
chubbs878's Avatar
If you want to retain the OEM tube with MS Tstat adapter, just cut 1-inch out of it to compensate for the adapter and weld it back up.
Old Jan 30, 2017 | 09:00 PM
  #27
Best4x4's Avatar
Yep exactly
Old Feb 1, 2017 | 04:40 PM
  #28
Luckyjayb's Avatar
Still waiting to hear back via email. Even called and no answer. Will try again tommorow
Old Apr 14, 2017 | 11:59 AM
  #29
chubbs878's Avatar
they never replied, did they?
Old Apr 14, 2017 | 03:11 PM
  #30
Luckyjayb's Avatar
Hell no
A5scott
May 28, 2019 07:23 PM
03discoman
Nov 18, 2016 02:01 PM
jamieb
Apr 10, 2016 09:20 PM
WARWAGON
Oct 2, 2012 12:03 PM
Street Wolf
Sep 27, 2008 08:58 AM
