New Timing Cover Gasket.....
2004 Disco 138000 miles. Looks like i finally found coolant leak to be coming from timing cover gasket. As soon as i put in new fluid it just pours out of that area. the job replacing it doesnt look to hard via Rave manual. But a couple questions....how long does this job normally take? Is there anything else i may need to replace while im in there? Also how can I tell if my fan clutch is bad? Thanks!!
whelp i got the new timing cover gasket on there along with a new oil pump. I installed a new water pump and t-stat a couple weeks ago. BUT....Now i have a new problem. The red overtemp light remains on all the time and the temp guage never moves. When I tried to crank it it sounded like it didnt want to start. Finally fired up but sounds like crap. When I accelerate there is a "tapping" sound almost like an exhaust leak. I drove it about a mile and turned around and came back home. Im ready to pull what hair i have left out.
outdoor7or24
12-22-2014 09:31 PM
Marni
06-22-2013 05:04 PM
