No Compression on left side
I purchased the truck non-running. The previous owner said the timing chain needed to be replaced. I removed the value covers on the left side and could see the rockers moving so i figured it was not the timing chain.
You say the valves move so more than likely nothing is completely broken but it may be worn badly. Some disassembly will be required to determine that......Dan
I started pulling the heads today and got down to removing the head bolts before it got to dark to work. I did notice that a couple of the bolts where extremely easy to remove and the two outside ones on the inside of the head where very hard to remove. I will finish getting off the heads after work and report my findings.
