No Dome Lights
Old May 16, 2009 | 11:00 AM
denisboyle's Avatar
6th Gear
Default No Dome Lights
Hi Guys
Two weeks ago I got 02 Disco with 60k . So far I have been able fix everything but my dome lights. I Have Checked the fuses and bulbs.
I think the problem maybe with the remote keyless entry or fade away dome light feature. Any one know if the truck has a lamp delay module or if it runs through the BCM. Maybe someone can point in the right direction
Thanks
Denis.
Old May 16, 2009 | 12:19 PM
Will any of the doors activate the lights, even the tail gate?
Old May 16, 2009 | 01:12 PM
denisboyle's Avatar
6th Gear
Hi Mike
No none of the doors activate the lights. But when I open the drivers door with the key in the ignition the chime works. So I think the BCM is seeing the door open.
Thanks
Denis
Old May 16, 2009 | 01:19 PM
Is the 3 position dome light set at the right position?
Old May 16, 2009 | 01:51 PM
denisboyle's Avatar
6th Gear
Hi Mike
I wish it was that.
Thanks
Denis
Old May 16, 2009 | 05:20 PM
If the door chime works and you have checked/replaced everything else then it must be a BCM issue.
Old May 17, 2009 | 06:08 PM
denisboyle's Avatar
6th Gear
Thanks Guys
I was hoping for test to pin point the problem.
Thanks again
Denis
Old May 17, 2009 | 06:13 PM
Please let us know what you find out so that we may help others with a similar problem if it comes up.
Old Sep 27, 2009 | 11:26 PM
ngv151515's Avatar
i have the same problem... i need my dome lights
jussnb
Aug 13, 2013 09:19 PM
josemex
Aug 2, 2010 12:07 PM
blast20
Apr 23, 2010 04:18 PM
nestep
Aug 15, 2008 08:11 PM
djones70
Apr 3, 2008 02:24 PM
