No fires please - Temp/Oil/Grease
Old Oct 8, 2015 | 04:03 PM
robert.juric's Avatar
Some people install a separate coolant temp sensor. I just use an UltraGauge because I like the exact reading from the ECU instead of the vague stock gauge. I guess it just depends on how much modification you want to do.
I would like to add oil pressure one day though at which time I might get add an extra coolant temp sensor.
Old Oct 8, 2015 | 07:25 PM
Joemamma1954's Avatar
Originally Posted by LandyMatt
I didn't consider the UltraGauge because it relies on the ECU. My thought was it would be better to have a 2nd independent temp sensor with all the overheating issues. Is that overkill? I'm planning on sticking with oil pressure and not oil temp.
I don't have the white gauges, it was just a clear pic of the cluster from Google.
Thanks for the feedback.
Not overkill at all, probably more of a necessity.I will be installing both oil pressure and coolant temp on pillar one of these days.
Old Oct 9, 2015 | 02:21 AM
LandyMatt's Avatar
I'm now confused by the terms sensor and sender. Same thing? Stock DII only has one?
To confirm, the ECU tells the cluster temp gauge what to display? This is the programming problem that makes the needle stay still until it's actually boiling?
So there is no way to stuff new gauge parts into the existing cluster using the ECU feed. I would need the 2nd sensor/sender.
Old Oct 9, 2015 | 05:20 AM
drowssap's Avatar
most after market setup also go in the upper hose, were the stock unit is in the lower intake. so installing a separate gauge is much more beneficial than just piggybacking off the ecu signal. imho
Old Oct 9, 2015 | 07:25 AM
For general purposes a sensor/sender are the same. I believe technically a sensor is used to send information to an ECU and the sender is capable of sending directly to a gauge.
And yes the ECU tells the cluster temp gauge what to display, its just at what temp the needle moves is a problem. If you were using an UltraGauge to monitor the reading you could see swings from 180-220 and the needle would never move.
Old Oct 9, 2015 | 01:18 PM
I think the gauge step motor was intentionally set to not fluctuate. Most likely to keep owners from freaking out, because these engines do fluctuate 15-25 degrees. The needle would be moving constantly.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
tacomatech
Oct 22, 2008 10:08 PM
nathan214
Oct 21, 2008 06:21 PM
janikphoto
Defender
Mar 14, 2008 01:11 PM
