No Headlights 2002 Disco 2
You are in Canada, correct? (and your Disco normally has Daytime running lights activated when you shift into gear then, correct)?
Does it click when you are in PARK with the headlamps off?
When there is a problem with the DRL resistor behind the LF headlight you will get this rapid clicking (that's pretty loud) from the interior fusebox under the steering wheel.
This could be the problem.
Have you done any work around the LF headlight assembly recently ? I would remove the headlight (easy, 3 tabs you slide over), reach down and disconnect/reconnect the wiring to the resistor (a bit silver metal thing), maybe that will do reseat a connection and fix the problem, if you're lucky?
You might also just be able to code the car (Nanocom or similar) to turn off DRL and it may fix the problem too.
It could also just be a bum / bad passenger compartment fusebox.
See attached for some context.
anbran (01-20-2021)
Yes...It's Canadian (with DRL). I noticed a problem with the LF DRL running dimmer that the RF DRL lately...
Yes...The DRL normally go on when I put it into gear...
It does not click when the vehicle is in PARK...Only when I put into gear...
Thanks!
...I'll have a look behind the LF headlight
Thanks!
I've taken the headlight out and located the "big silver thing" resister. I unplugged it and everything works properly now...except, of course, the DRL. They are non functional...which is fine for now. I can use the main headlights all the time.
You're saying I can reset the resister by plugging it back in? I will do that and see if it fires up the DRL again.
If this doesn't work, are new resisters available?
anbran (01-20-2021)
Brandon318
10-12-2019 10:04 AM
Nunezjoel13
01-28-2018 06:31 PM
