NO interior lights.
Old Jan 18, 2009 | 03:36 PM
tlittlej's Avatar
3rd Gear
Default NO interior lights.
03 Disco SE7. Front,rear and load lamps will not come on. Passanger comartment fuse 20 is good. Bulbs are good. Ignition switch light functional. When front lamp is in on position occasionally a very faint glow of the filament can be seen only when the lamp cover is off. Glove box lamp is good but will not illuminate either.This is my first post and I could really use some feedback. Thanks for any help.
Old Jan 18, 2009 | 04:53 PM
Default RE: NO interior lights.
So when you turn the switch to "ON" the light still does not work?
Or ot works very faintly?
Old Jan 18, 2009 | 06:44 PM
tlittlej's Avatar
3rd Gear
Spike555,
Yeah the front light will only faintly glow when it is in the on position. It will not come on if in the "door" position with a door open.
Old Jan 18, 2009 | 07:02 PM
Have you tried replacing the bulb?
Old Jan 19, 2009 | 11:21 AM
tlittlej's Avatar
3rd Gear
Spike555,
Changed the bulbs and rotated bulbs between the interior lamps and glove box. Front lamp, regardless of which bulb, was the only one that would have the faint glow. Also, noticed that some of the switches on the ac/heat controls don't illuminate. The disco has dual zone heating/cooling. The temperature regulation switch for the driver has been out while the passenger switch still illuminates. None of the other switches on the module illuminate whether ac/heat is on or off. When it is on the backlight for temperature reading etc. does illuminate. I appreciate your help.
Old Jan 19, 2009 | 01:21 PM
That is very weird. I have had dim interior lights on a different car before, repalced the bulb and all was fine.
I am at a loss for your problem though, sorry.
usnavylt
LR4
May 1, 2015 03:40 AM
outdoor7or24
Sep 6, 2012 10:32 PM
mignum
Dec 14, 2009 07:34 PM
bigharp
Sep 29, 2009 03:57 PM
DPR81
Feb 3, 2009 05:13 AM
