No Luck Here!
Old Apr 5, 2011 | 10:25 PM
  #61
mwindth's Avatar
Originally Posted by Wolf
Haven't done the flush and refill with 50/50 yet, found my overheating problem to be the new T-stat. If your really wondering if it's working, no need to pull and boil. Just run it till the temp creeps up above normal, pull over, shut down then grab the bottom hose from radiator to T-stat. If it's ice cold then the T-stat is not opening. Disco Mike and I had a good laugh about that today on the phone. Thanks for the call Disco Mike if your reading this, very nice to hear from you and Thank you, you confirmed my thoughts on what was going on. Gotta go, my wife is on my backside for being online, go figure!
I'm glad you figured it out Wolf...defective T-stats has been mentioned on this forum in the past as a culprit to overheating.
Old Apr 6, 2011 | 07:50 AM
  #62
Wolf's Avatar
I talked to Disco Mike yesterday and he said that there has been a 60% failure rate on LR T-stats, very high. I will never assume since it's new that it works, at least not a LR part. What I've learned is always test first before install. Wish I would have found this to be the issue before I spent $350.00 on a radiator and four hours to replace. Live and learn, good thing I'm having fun doing it.
tornado_735
Apr 24, 2009 07:33 PM
lk311
Nov 25, 2008 10:29 AM
Maximuse34
Jan 1, 2008 03:35 PM
Roverboy3766
Nov 13, 2007 10:33 AM
BostonBB
Sep 18, 2007 06:49 AM
