Transmission issue, I searched no luck...
Old Dec 30, 2007 | 11:05 PM
Maximuse34's Avatar
3rd Gear
Default Transmission issue, I searched no luck...
About two days ago I heard a faint sound from under the truck. It is a 94 D1 auto. It has gotten louder over the past two days. It sounded like I had a bolt come loose from the torque converter and was bouncing around the bell housing. After removing the inspection plate that was not the case. I have traced the rattle to the back of the transmission about where it attaches to the transfer case. I drained the tranny fluid and found metal shavings on the drain plug.
I am confuse as to what it could be. The sound is there when the tranny is in park or neutral or anything. I cannot come up with anything that would even be turning back there without the truck moving to make the rattle. There is no loss n power or difficulty in shifting so I am out of ideas. I have not taken it to a shop yet since I like to try to find out if it something simple first.
Any ideas of what the cause is or if this has happened to you please share your great knowledge with me. Thanks in advance!!
Rob
Old Dec 31, 2007 | 12:05 PM
Maximuse34's Avatar
3rd Gear
Default RE: Transmission issue, I searched no luck...
No body have any ideas?
Old Dec 31, 2007 | 12:46 PM
You are going to need to get this into a small tranny shop and let them listen to it. I would suggest you not drive it till you can have it checked.
Old Jan 1, 2008 | 03:35 PM
Maximuse34's Avatar
3rd Gear
Thanks Mike, I have decided to do just that. I have also located a replacement if needed. I have had relativiely minor issues ever since I bought it so I would like to keep it that way.
ThorsDiscovery
Mar 27, 2016 06:24 PM
bikeG976
Dec 21, 2009 10:47 AM
tskeltonPGA
Jan 16, 2008 07:21 PM
MEP
Nov 8, 2007 09:59 AM
Ramathorn
Aug 26, 2007 11:29 AM
