No Parking or Tail Light 2003 Disco
Hi guys,
Been beating my head against the wall on this one. I have turn signal on Passenger side, brake light, but no parking or tail light. I have replaced the bulbs with no effect.
Is there a fuse or relay that operates these two lamps? The rear right fog lamp works, as well as the reverse lights. In the meantime I'm running the rear fogs to compensate for no right rear tail light.
I have checked the connectors, all are in clean condition. My trailer plug checks out okay, with no errors.
Thanks for your help, and ideas in advance.
you know the funny thing is my headlight would fail but not always. It wouldn’t happen all the time. I tried cleaning the switch and sometimes it would work. But then it failed again. So I bit the bullet and bought a new oem switch and haven’t had any problems since.
