No power to fuel pump 2004 Discovery
Old 12-05-2018 | 12:56 AM
PowerRov's Avatar
Default No power to fuel pump 2004 Discovery
I did the cardinal sin and ran her dry. I have
Old 12-05-2018 | 06:12 AM
PowerRov's Avatar
I have:
Reset the inertia switch.
Filled the tank with 3 gallons of fuel
Pulled the pump to check for debris, no debris found.
After pulling the pump the pump didn’t turn on
Tested the pump by connecting a battery directly to the pump and it ran
ive tested continuity on positive and ground wires from the connector at the pump all the back to the relay, ‘0’ ohms all the way.
Disconnected the inertia switch and jumped it
The engine cranks and starts about every 3rd try after I ‘prime’ it by connecting the test battery directly to the pump but the engine will only run for 2 seconds then quits.
I am at a loss and need to get it fixed.
Old 12-05-2018 | 06:49 AM
mollusc's Avatar
You've checked the fuel pump fuse, right? (Fuse 10 in the engine compartment.)
Old 12-05-2018 | 08:15 PM
PowerRov's Avatar
Yeah, I’ve checked every fuse under the hood.
Old 12-06-2018 | 03:31 PM
JUKE179r's Avatar
Check the relay too. Make sure it’s inserted correctly.
If it is, pull it out to make sure it’s not burned at the relay contacts.
Old 12-06-2018 | 04:01 PM
mollusc's Avatar
if the fuel system ran dry, could it be that it needs to be primed in order to come up to pressure?
Old 12-06-2018 | 08:34 PM
PowerRov's Avatar
I checked the relay and it looks good no discoloration on any terminals. How would I go about priming the line? When the engine cranks and doesn’t start, it sounds like it’s not firing on all cylinders. If the fuel line was airlocked would that cause the pump not to turn on?
Old 12-08-2018 | 12:07 AM
Stein's Avatar
Does the pump run when you crank the engine?
As far as I know the pump doesnt start up until you start cranking unlike most cars that run the pump for afew seconds when you first switch the ignition on.
If there is air in the lines, then it might not be getting enough fuel to start the truck. Try hooking the pump up directly to power and wait 10 seconds then crank for afew seconds then wait again and repeat to clear out any remaining air.
a-merry-can
01-26-2018 05:28 PM
royageor
10-02-2015 08:01 AM
zombiedisco
03-22-2012 04:02 PM
bilmgl
10-24-2011 09:11 AM
DISCOLIVES
02-26-2008 03:36 PM
Quick Reply: No power to fuel pump 2004 Discovery
