Sponsored by: CARiD
NAS D90 fuel pump issues. Help!
Old Nov 16, 2017 | 09:06 PM
a-merry-can's Avatar
4th Gear
Default NAS D90 fuel pump issues. Help!
Hi lads,
my my defender has been reluctant to start lately, until it just won't. I noticed the fuel pump wasn't kicking on when I turned the key, so I replaced the fuel pump relay. Still won't start. Tested the relay which works fine. Looked at the fuse, not blown. Tested fuse, it's fine. I checked the fuse panel under the hood, all of those fuses were fine, too. It must be the fuel pump, so I did the nasty, dropped the tank and soaked myself in gas. I hope I never have to do that again. Anyway, no joy. Fuel pump won't kick on. Tested old pump, much to my dismay, it's fine.
Replaced the coil and amplifier, in case the spark was weak. Tested it with a plug against the block. Sparks great.
If if the relay is getting power, and it clicks... And the fuel pump is brand new, why won't it start?? I'm starting to think the ol girl is jealous of the muscle cars.
Any thoughts of of what I might check?
Old Nov 17, 2017 | 07:28 AM
WaltNYC's Avatar
what year? what engine? (best to put this info in your signature so you don't need to repeat it continually)
Here is the text from the ETM for a 1997MY.
STARTING - OPERATION
When the ignition switch is in position 'II', power flows across the switch to fuse 20 of the
passenger compartment fuse box (C581-13) on the white wire. Fuse 20 (C581-20) is
connected to the fuel pump relay winding in the ECM relay module (C154-2) by the
white/green wire. The fuel pump relay winding (C154-1) is grounded through the ECM
(C634-24) on the blue/purple wire. The ECM grounds the fuel pump relay winding for a
short time when the ignition is switched to position 'II', and continuously during cranking
and while the engine in running. With the fuel pump relay winding energized, the fuel
pump relay closes and power from fuse 6 (C575-2) of the engine compartment fuse box
flows through the fuel pump relay (C157-7) on the purple/white wire. The fuel pump relay
(C157-4) is connected to the inertia switch (C123-3) by the white/purple wire. Assuming
the inertia switch is closed, power flows across the switch (C123-1) to the fuel pump
(C113-4) on the white/purple wire. The fuel pump is grounded on a black wire.
Turning the ignition switch to the crank position 'III', allows power to flow across the
switch (C90-1) to the starter relay winding (C151-85) on the white/red wire. The starter
relay winding is grounded on the black/yellow wire to the starter inhibitor/reverse switch
(C69-5). With the gear selector lever in park or neutral, the route to ground is from the
inhibitor switch (C69-4) to the immobilization unit (C57-10) on the black/orange wire.
Assuming the engine has been mobilized, the immobilization unit is grounded on a black
wire. With the starter relay energized, power from fusible link 5 of the engine
compartment fuse box (C570-2) flows across the relay (C151-87) on the brown wire.
The starter relay is connected to the starter motor solenoid (C179-1) by the brown/red
wire. The starter motor solenoid is grounded through the starter motor fixing. With the
starter motor solenoid energized, feed from the battery is connected to the starter motor
(C178-1) through the starter solenoid on a red wire.
Possibly the inertia switch.
FYI, most of the workshop manuals and electrical manuals can be found in the link in my signature. Help yourself to whatever you need.
Old Nov 17, 2017 | 11:46 AM
4th Gear
Point taken, sorry! I thought NAS 90 was enough. It's a 1995 Defender 90SW with a 3.9 petrol engine and a 5 speed. I'll look into the inertia switch next. Eventually I'll replace the part that's boogered up! Thanks for the link to the tech docs, too I'll dig into those more tonight.
Old Nov 20, 2017 | 05:48 AM
4th Gear
OK. Frustration time. Here's where I am with the fuel pump issue...
  • I've replaced the original fuel pump with a new one (then bench tested the original, only to find it works). Taking that tank out is something I hope I never have to do again!
  • I've removed all the fuses from the fuse box under the dash and bench tested them, they're fine.
  • I've removed all the fuses from the panel behind the engine compartment and bench tested them, they're fine
  • I've removed the inertia switch and bench tested it, it's fine. I even bypassed itt o make sure, still no fuel pump.
  • I replaced the fuel pump relay, and bench tested the original... it's fine as well.
Basically, I've checked every single component between the battery and the fuel pump and they all check out. Is there anything I'm missing? I really don't want to have to go through the tank thing again (though I'm sure I can do it in half the time now). The only think I haven't checked is the current to the relay on the pump side. If that checks out, then it has to be a broken wire, I guess?
Thanks in advance!
Old Jan 26, 2018 | 05:28 PM
Dustin Burch's Avatar
Default fuel issues
Thanks in advance!
Hey man,i'm having the exact same issues as you... did you ever find out what the problem was, and if so, what was it... Thanks,DB
KMD LR
May 16, 2019 05:52 PM
Baylink
Sep 21, 2017 06:46 PM
KMD LR
Aug 20, 2016 07:44 AM
worsethenu
Apr 23, 2013 10:16 AM
gdtna
Defender
Jul 11, 2009 04:38 PM
