No power under a load
Old Feb 18, 2012 | 01:46 PM
You really need to take it back to him, he "fixed" it, it should be fixed.
Or you get your money back for labor at least.
Old Feb 18, 2012 | 02:04 PM
Just had a thought, it could be a bad fuel injector.
Old Feb 18, 2012 | 02:05 PM
rholtporsche's Avatar
Could a compression leak cause a misfire?
Old Feb 18, 2012 | 03:52 PM
Yes a compression leak could cause a misfire.
Typically what happens on these newer engines is the block cracks, you get a misfire and coolant leak.
New head gaskets, problem still there, loosing coolant and misfire.
The crack is microscopic so it cannot be seen except under a special test.
But you say you are not loosing coolant.
What really sucks, you could have gotten a whole new engine for about $5200 shipped from the UK.
Old Feb 18, 2012 | 07:40 PM
I'm not losing coolant.
I knew about the engine. I throw up in my mouth a little every time I think about it.
Old Feb 18, 2012 | 09:54 PM
I feel your pain.
They were just trying to help and they got screwed and lied to.
Not loosing coolant, replaced plugs, wires, coils and heads, so I am going to say it is a bad fuel injector.
So, unplug that injector, does it run any different?
No?
Theres your problem.
Yes it runs worse, we need to keep looking.
Old Feb 18, 2012 | 11:11 PM
I appreciate it. I'll give that a try tomorrow and post. I love the disco. Ladder, bfg's and roof rack, but I'm not sure... I can't even say it
Old Mar 8, 2012 | 04:12 PM
Anyone know if my bad fuel economy and loss of power and cyl misfire could be from a knock sensor that might be going bad, even though I didn't get a code for a bad knock sensor?
Old Mar 9, 2012 | 06:51 AM
drowssap's Avatar
is there a reason your not taking it back to the guy who took your parents for $5000.00? They had to get some type of warrenty for that type of money.
Old Mar 9, 2012 | 10:03 AM
Dave03S's Avatar
Your symptoms could also be caused by a worn cam shaft.
