No spark on a new to us 2003
Yeah, I definitely didn’t have the proper sections of the manual. I’ve found it now and will parse through it.
Pull a spark plug and see if you're getting any spark while cranking. Then pull the injectors off and leave them connected to the wiring and see if they squirt fuel while cranking.
Another alternative is to swap ECU / BECU / instrument cluster and see if it will run with different ECU. I did have one die once
It’s always good to have a spare Rover lying around! I swapped out the ECU, BECU and cluster from my ‘04. I was a little disheartened when the security light came on and it wouldn’t crank. I remembered reading somewhere it needs to sit with the key on for 10-15 minutes. After that the red light was out and she cranked over. It took a few try’s, but she fired up! Now to find him parts so I can have line back!
Boutins
09-05-2010 06:59 PM
