2003 Discocery ii is Not getting Spark
I own a 2003 Land Rover Discovery ii SE. I have replaced the Head gaskets, Valve cover gaskets, intake gaskets, head studs, head plugs, spark plugs, battery, power steering pump, starter, CRANKSHAFT SENSOR, serviced the transmission and the thermostat seal, Removed the catalytic converter replacing it with a pipe and now am getting no spark...any suggestions? Note: the crankshaft sensor works both fuel and spark, while the camshaft is all about timing...so I am confused and befuddled!
