No start and the Green Transmission Lights are Flashing
Old Feb 4, 2013 | 11:53 PM
Joe Pundzak's Avatar
4wd High
Default No start and the Green Transmission Lights are Flashing
99 DISCO II, 214,000 miles
She's running fine one day and won't start the next. The two green transmission lights at the bottom of the instrument panel are flashing and the operating manual says - electrical fault in automatic transmission - see dealer NOW.
WTH?
Trying to avoid a large towing charge to the dealer if possible, but no one within 50 miles has a LR code reader.
Any suggestions or recommendations aside from setting it on fire?
Appreciate the help.
Old Feb 5, 2013 | 12:13 AM
If the M & S lights are on, and check engine light is NOT, then the shop manual says that is tranny senses battery volts at 9 volts. Would suggest you check charge of battery, loose cables on battery, loose cable from (-) battery lead to frame or chassis. By the way, when doing all this, be sure to depress the hood alarm switch, so if you jump off truck it won't wake up and think a thief has control and immobilize the engine.
Old Feb 5, 2013 | 11:38 AM
Dave03S's Avatar
Any OBD2 code reader will work for this, you only need a special code reader for ABS related issues.
Since you appear new, don't go to a dealer, ever, for service. Find an independent Land Rover specialist, not a "foreign" car shop.
Dealers and "foreign" car shops see LR owners as a wide open walking wallet with an unlimited Visa Platinum card.
Old Feb 5, 2013 | 11:55 AM
FlyingZebra34's Avatar
the battery m8
Old Feb 8, 2013 | 03:31 PM
4wd High
A note of thanks to those who responded with super information ... just an update, the real problem turned out to be either mice or rabbits ... the entire wire harness out of the fuse carrier was chewed to bits ... since this damage is covered by my insurance, it's off to the dealer ... don't really mind them soaking the insurance co.
Old Feb 8, 2013 | 04:11 PM
greenharoguy's Avatar
I would go with setting it on fire.
Old Feb 8, 2013 | 04:23 PM
RoverMasterTech's Avatar
I 2'nd fire.
Old Feb 8, 2013 | 07:04 PM
jfall's Avatar
Where do you park to get mice?
May have been squirrels.
They chewed a ground wire on a guy's truck at work
a Dodge Dakota.
His whole dash went out.
Old Feb 8, 2013 | 07:42 PM
I spent a day this week fixing squirrel gnawed wires on the ignition for my John Deere riding mower, and got the grass cut for first time of the season. Just glad I didn't have to buy a $300 module....
Old Feb 9, 2013 | 10:16 AM
4wd High
@Greenharoguy/RoverMasterTech - Roger that on the fire ... very funny and tempting!
@jfall - I park in my driveway ... with the 2" lift and a roof rack, she's too tall for the garage. We live in a quasi-rural area so wildlife and critters are the norm and not the exception. I keep D-Con in the truck, so you're probably right that it was either squirrels or rabbits ... the nest was pretty big. I'm getting a ration of crap from the wife because I didn't notice it sooner.
@Savannah Buzz - Damn rodents may be cute, but they do cause considerable damage...I'm still waiting for the other shoe to drop, God only knows what 'other' electrical damage the rodent damage may have caused. I'm sure the dealer will be most creative in discovering all sorts of additional related problems ...
Anyone got a match?
