Noise After Shifter Install
Old Jun 11, 2012 | 04:32 PM
FLDiscoII's Avatar
Default Noise After Shifter Install
So I finished up with the D1 CDL shifter install. After getting everything put back together, I moved the shifter, with the truck in neutral, to test out the linkage. Everything moved smoothly so I took it for a drive, in high/unlocked. I noticed that at about 25-30 MPH, under acceleration, I could hear a faint rotational noise coming from the transfer case/tranny area. At a stoplight, the idle felt rough under the seat. So I dropped it into neutral to make sure I was still in high/unlocked...I was. It wasn't doing this until after I engaged/disengaged the CDL for the first time after the install. The tranny and T/C were both serviced about 850 miles ago with new fluids and a new filter for the tranny. Other than the faint noise and a slightly rough idle under the seat it is running fine. Any ideas what might be going on?
Old Sep 1, 2013 | 11:49 AM
nac's Avatar
nac
did you figure out what the problem was? Mine is the exactly the same thing as your after I install a shifter in.
Old Sep 2, 2013 | 09:59 AM
Normal when using a D1 shifter. You might consider removing the tunnel plate again and use a piece of heavy inner tube rubber to cover the entire opening then reinstall the plate.
Old Sep 3, 2013 | 07:44 AM
nac's Avatar
nac
Thanks,
I also notice that only after been driving for 30+ mins.
instg8r
Jun 2, 2019 05:07 PM
Francopacks
Apr 30, 2013 12:33 AM
dcarr1971
Oct 26, 2010 01:26 PM
NiteTrain
Mar 30, 2010 10:11 AM
03discoman
Nov 2, 2009 07:29 PM
