D1 CDL Shifter install question
Old Oct 25, 2010 | 03:37 PM
dcarr1971's Avatar
Default D1 CDL Shifter install question
OK...so I've read through the instructions and have been searching several forums for hints about where to source the parts. I have everything I need to start the swap except the "10mm to 6mm bore reducers".
Where did you obtain these parts? I've tried all the local hardware stores (Home Depot, Lowes, Ace), Auto Parts stores (Advanced, Napa, Autozone), and even Fastenal. Nobody seems to have this item.
I know a lot of other D2 owners have completed this upgrade, so, where did you find this part, or how did you address the need for it?
Old Oct 25, 2010 | 03:42 PM
jackstraw's Avatar
I couldn't find them either. I just used the 6mm bolt and nut with washers. So far so good.
Old Oct 25, 2010 | 04:18 PM
NiteTrain's Avatar
I found some bushings at www.mcmaster.com I forget the part number..they have A LOT of hardware
Old Oct 26, 2010 | 12:58 PM
dcarr1971's Avatar
They sure do have a huge selection...do you remember whether you used a part with a 10mm outside diameter? The directions I've seen appear to differ on when size to use (8mm vs 10mm). From what I can find, it doesn't look like they have one with an 8mm outside diameter except for this: http://www.mcmaster.com/#reducer-bushings/=9g1wat
Old Oct 26, 2010 | 01:26 PM
NiteTrain's Avatar
i think this is what i ended up using
http://www.mcmaster.com/#sleeve-bearings/=9g2a72
turbodave
Mar 29, 2019 07:22 AM
nosup4u
Apr 16, 2014 08:33 PM
Francopacks
Apr 30, 2013 12:33 AM
br0keit
May 10, 2012 08:34 AM
NiteTrain
Mar 30, 2010 10:11 AM
