Noise at the bottom of the A filler
Old Dec 19, 2017 | 07:35 PM
honghanbyul's Avatar
6th Gear
Default Noise at the bottom of the A filler
Hello
I am a Land Rover beginner in Korea.
I have one problem.
It's just a bad feeling.
This is due to the noise coming out of the fan.
The largest at the bottom of the driver's seat A pillar.
Can I fix it simply?
Do you have the answer to this question?
Do not heat the heater or the air conditioner. The noise continues.
Noise is heard even if only the electric device is driven by turning the ignition key halfway.
thank
Hong
Old Dec 20, 2017 | 06:45 AM
mollusc's Avatar
To the left of the steering wheel, just above the fuse box cover where the mirror adjustment **** is, there's a small vent. There is a tiny fan behind that which circulates cabin air to take the temperature and send that info back to the climate control. That fan tends to accumulate dust over time, so it's my guess that your problem is there.
Or something is shorting the small speaker in the A pillar and causing it to crackle.
Old Dec 20, 2017 | 05:37 PM
6th Gear
Default thank
thank
Actually, before I run the ripple.
I opened the glove box under the steering wheel.
As you say
Noise was heard in the fan circulating the air.
I am trying to fix this.
I ordered the BW-100.
I hope this works.
Thank you very much for your reply.
Hong
fp360spidr
Jul 22, 2007 03:05 PM
dalfier
Jun 18, 2007 06:51 AM
jacksyachts
May 2, 2007 11:49 AM
imag
May 12, 2006 07:59 PM
mmh
Dec 25, 2005 10:24 AM
