Noise in engine .. Help!
Old Mar 1, 2016 | 10:59 PM
jfall's Avatar
That noise is either a slipped liner or it is a bad main bearing.
If it is a bad main bearing or rod bearing, don't drive it as it will throw a rod and put a hole in the oil pan or the block.
If it is a liner - the way you tell is -
If it is quiet in the first three minutes when you start it and then after driving a mile
this sound comes - then it is a liner slipped and thrashing up and down.
Solutions:
1) If a liner - PIN the liner with a screw into the block.
2) If it is a bad rod or main bearing - replace all the bearing shells and that will solve it.
You may have a scored crank shaft now - and if that is the case - whole rebuild.
A 2003 engine does have slipped liner problems - so cut your losses.
Fold the cards.
Old Mar 1, 2016 | 11:00 PM
jfall's Avatar
Don't put money into it.
Get a used LR3 or LR4
Eulogio
Jan 21, 2008 04:17 PM
mc_eyes
Oct 10, 2007 12:41 AM
flyingasics
May 29, 2007 10:16 PM
tobob1
Nov 27, 2006 02:11 AM
tobob1
Sep 11, 2006 09:14 AM
