Noise from transmission
Old Jan 19, 2014 | 12:41 PM
zenithgarfunkel's Avatar
8th Gear
Default Noise from transmission
I've been working through the major service list on my 2003 and drained the fluid from the transmission. I replaced the filter and cleaned out the sump pan and magnet. I followed the procedure filling the sump back up then continuing to fill it while it was running.
Since servicing the transmission, it has started to make a whirring type noise when in reverse. It only makes this noise when started from cold and the noise goes away after it warms up. The transmission still shifts fine and I have not noticed any other changes.
I tried draining/filling it again and I added a bottle of lubegard. It is still making the odd noise in reverse from a cold start.
Any ideas or things I should try?
Old Jan 19, 2014 | 02:39 PM
JJG623's Avatar
3rd Gear
I have the same noise but mine does it all the time in reverse, warm and cold.
mattrickman
Jan 17, 2011 01:54 PM
ColoDisco
Aug 14, 2009 01:33 PM
jycsalas
Jul 1, 2009 09:14 AM
98DiscoC
Feb 26, 2008 08:20 PM
prologic
Jun 2, 2005 03:19 PM
