Noise when coasting
Old Aug 21, 2024 | 12:25 PM
  #21
mollusc's Avatar
That brake acts on the rear driveshaft. It could therefore still be an indication that the rear differential is the issue -- the brake shoes could be damping the vibration that's causing the noise.
You should only be using the CDL when you disconnect the driveshafts. For one thing, you shouldn't drive on high-friction surfaces with it engaged; for another, it probably won't tell you anything about your problem.
Old Aug 21, 2024 | 01:18 PM
  #22
mcbrl's Avatar
Thanks - a lot of people seem to suggest that test to isolate the problem.
Ok thanks - at least I am getting closer to the source of the problem (I think )
Old Aug 21, 2024 | 01:33 PM
  #23
mollusc's Avatar
No they're not. They are suggesting that you use the CDL when you have removed each driveshaft.
Old Aug 21, 2024 | 02:07 PM
  #24
mcbrl's Avatar
Yep, that is what I meant / understood from the messages
Wayne12
Sep 12, 2021 11:55 PM
5280LR3
Jun 7, 2019 01:04 PM
windsoreight
Jul 15, 2014 06:37 PM
windsoreight
Jun 28, 2014 04:52 PM
ezioc
Aug 14, 2007 11:58 AM
