Non-oem roof ladder install
Old Jan 5, 2009 | 01:17 PM
salve7's Avatar
Default Non-oem roof ladder install
I was looking at the instructions (http://www.roverparts.com/Instructio...adder_8-13.cfm)that came with the roof-rack ladder that I bought from atlantic british and it is NOT calling for rivets or bolts. It just says to drill a pilot hole and screw what looks like sheet metal screws directly into the back hatch. What are your thoughts on this? Am I fine with just the screws or should I rig up some bolts? I have never used a rivet gun before so I don't know the pros and cons on that method... Any advice would be appreciated!
Old Jan 5, 2009 | 01:36 PM
avking's Avatar
Default RE: Non-oem roof ladder install
My van has a rear ladder and it is simply scewed in with sheetmetal screws. No problems with it after a couple years and some VERY heavy loads going up and down it.
Old Jan 5, 2009 | 04:47 PM
Camdisco24's Avatar
Assuming that the Non-oem is the same as oem from an installationstandpoint, then you should be fine using the sheetmetal screws. I did mine that way it is very solid, and I just used a regular power drill. Just be sure it is perfectly lined up before you do it because once its in, ITS IN!
Old Jan 5, 2009 | 05:15 PM
jkid's Avatar
I've never seen how one of these is installed, but it looks like there is a bracket at the top of the ladder that fits over the top of the door and the screws just keep it from moving around. If that's the case thenit looks like it should hold just fine even without any screws in there. SoI say screw it , no bolts needed.
Old Jan 5, 2009 | 08:20 PM
Urban Panzer's Avatar
mmm, using sheet metal screws instead of rivnuts and bolts...........not my idea of a solid fixing, but each to their own.
Old Jan 6, 2009 | 12:33 PM
salve7's Avatar
I went ahead and mounted it and it looks like it will remain solid... didn't take long at all. Thanks for all the feedback!
mroorda
Nov 1, 2012 08:15 PM
Landafun
Apr 1, 2012 06:49 PM
stormtrooper
Aug 31, 2009 03:54 PM
sdsilvere38
Oct 16, 2008 08:29 PM
sdsilvere38
Oct 1, 2008 12:37 AM
