Non start, battery fine. I think.
Old Feb 16, 2015 | 05:31 PM
dr. mordo's Avatar
I agree a battery test is the first step. A battery can show 12v and still be bad. If its bad, the voltage will drop as soon as it has a load on it.
Old Feb 16, 2015 | 10:46 PM
abran's Avatar
It's your battery. I just went through this on my P38. Sat for a while. Turned the ignition and got a rapid clicking sound.
Put some quality jumper cables on it and same thing.
Assumed it was the starter. I hit it with a hammer, nothing.
Resolved to change the starter, but was dreading it, so... I switched out with a battery from my disco and Voila!
Old Feb 17, 2015 | 07:03 AM
cappedup's Avatar
Cheers Abran.
That's the only thing that's got me stumped. Wih jumper cables from a running truck it wouldn't fire the starter. So I actually started to suspect my rather cheap jumper cables.
I have a mind to swap the battery anyway. Even though, now after starting with a booster pack it's running fine.
I also have to leave it sitting at times. Up to two weeks.
Not ideal.
Old Feb 17, 2015 | 03:00 PM
cappedup's Avatar
Took the truck and a battery (AAP Silver Doohickey craft Blah....) I found in the back of the garage to AZ.
Battery on truck tested bad, back of garage one tested good, so it has a full charge and is on the truck.
Now, there is a reason it was stuffed at the back of the garage, and I can't remember what it is. But for now it's better than one that tests bad.
Seeing how I go.
Old Feb 18, 2015 | 07:49 AM
drowssap's Avatar
you do know that that green **** is a battery disconnect switch right? did you put that in there or was it always there? have you removed the disconnect and tried it without it?
Old Feb 18, 2015 | 08:34 AM
cappedup's Avatar
Yes, I knew that's what it was. I checked it out, cleaned it, made sure it's very tight.
It's always been there. I hesitate to remove it, as I do see it as of benefit when I need. Unless of course it turns out to be the issue, then it's gone.
Scott Legan
Mar 2, 2020 06:35 AM
Disco2 MTL
Jun 2, 2017 07:30 AM
silar
Feb 16, 2014 04:59 PM
lipadj46
Aug 19, 2009 06:11 PM
arrkerr
Dec 14, 2005 10:06 AM
