Normal stat vs. inline stat
Old Jul 15, 2016 | 12:52 PM
  #31
DiscoCam's Avatar
Originally Posted by Alex_M
Yep. I don't recall what the effect is called, but here's why in essence. Inside the combustion chamber, air and gas is pulled in and fills the cylinder. Then, as everyone here knows, the spark plug sparks and ignites the air fuel mixture, but not all of the mixture ignites. The air/fuel right next to the cylinder walls doesn't become hot enough because the cylinder wall itself keeps it cool, leading to unburnt fuel and causing higher emissions. The hotter the engine runs, the smaller the unburnt gap is.
If you go on the Practical Engineering channel and look up the clear potato gun in slow motion video (I can't recall the name) it explains this very well.
As for passing smog, you shouldn't have any issue. The initial tests for vehicles are more strict than renewal tests.
Good to know that it will pass smog.
Old Jul 15, 2016 | 01:01 PM
  #32
CollieRover's Avatar
Hey Alex, or other guys with this mod. Does this give you more room behind the radiator?
I am wanting to put in an LS2 fan, but the original thermostat is hitting one of the fans. Does this clear up space?
Old Jul 15, 2016 | 02:54 PM
  #33
Bom2oo2's Avatar
Won't give you more room behind radiator, but since you wont have the factory thermostat housing you will gain a little room on that side,
Old Jul 15, 2016 | 03:26 PM
  #34
DiscoCam's Avatar
Yeah that's true. You basically delete the hoses on the passenger side of the motor because the thermostat isn't there anymore.
Old Jul 15, 2016 | 05:08 PM
  #35
I think we are talking about the same side and thank you. I flipped the fan and it fit. The larger fan is not as deep, but that is a story for another thread.
03discoman
Nov 18, 2016 02:01 PM
coors
Dec 13, 2015 11:52 AM
DiscoRover007
Jul 16, 2012 08:58 AM
ATLDisco
Apr 4, 2012 07:00 AM
Danny Lee 97 Disco
Apr 9, 2010 12:15 PM
