O Rings Trans / Oil Cooler How to Change
Old Oct 31, 2020 | 07:54 PM
Eljefe2020$'s Avatar
4th Gear
Arrow O Rings Trans / Oil Cooler How to Change
Greetings,
Can someone tell me what is the process to put new O rings on these lines going to both coolers? I see O rings inside the end of the line. I have a 2001 Discovery
Thanks,
Old Nov 2, 2020 | 11:48 AM
Harvlr's Avatar
The engine end is pretty easy, I think it's a 7/8" wrench, pull the line out. The old O ring will either be on the line, or stay in the engine. If in the engine remove it with a pick. Put new o ring on the line and reinstall. I haven't removed the oil cooler end on my Disco, but on a parts P38. The line nut was so corroded to the cooler that it destroyed it. Next time I'll try some heat. I'm sure someone here will have some advice on the cooler end.
Old Nov 2, 2020 | 05:11 PM
4th Gear
Thanks for the feedback took it a mechanic and he ended up cutting lines that he did not need to touch, I am now trying to correct his mistake.
hattbatt
Apr 21, 2017 01:50 PM
bmeier
Dec 27, 2016 04:21 PM
evoblade
May 11, 2016 01:42 PM
demonlarry
Aug 1, 2013 12:32 PM
javven
Jul 15, 2012 10:09 AM
