O2...another question from the pest
Old Mar 4, 2011 | 08:01 PM
jrm123180's Avatar
Default O2...another question from the pest
Where do the O2 sensor wires run to? It seems that they run to the back of the engine somewhere? I think they are connected wrong somewhere or not at all if that's possible when the engine swap was done. They few people who have read them said they do not thing the sensors are faulty as ALL 4 went at the same time and are not reading. Suggestions again from the experts?
I appreciate everyones help.
Old Mar 4, 2011 | 10:00 PM
DiscoIIBrandon's Avatar
They run up into the firewall below the glove box behind the kick panel to the ECM.
If you have the RAVE, you can look it up in the engine management system and see the entire circuit with wiring. The pink & brown wire in each o2 harness connector plug is the power wire, you can check the corresponding "prong" inside the connector to see if they are getting power. The other three correspond with the ECM and you can test them for continuity.
Are you getting codes? No activity?
caymandrew
May 2, 2013 06:25 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
russ00001
Mar 30, 2006 09:47 PM
Benhamtroll
Nov 18, 2005 03:49 PM
