O2 sensor connector replacement
Old Jan 27, 2025 | 01:42 PM
Bone9's Avatar
Default O2 sensor connector replacement
V8 O2 sensor 1 connector replacement. I've found the correct plug, seals and the 2 silver terminals but I can't find the 2 gold terminals. Does anybody have a source for these? They are Sumitomo 1500-0134
Old Jan 31, 2025 | 07:33 AM
WaltNYC's Avatar
https://www.corsa-technic.com/item.p...YK1dyPi53Euv37
looks like you are looking for 'PIN1'
Old Jan 31, 2025 | 08:36 AM
Bone9's Avatar
Yes but the gold version. All sorted now anyway. Cheers.
Old Jan 31, 2025 | 12:30 PM
RA122125's Avatar
Banned
This makes the whole ordeal much easier....
Amazon Amazon
Old Jan 31, 2025 | 01:28 PM
Bone9's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is no good as it has 4 silver pins. The oxygen sensor and the plug on the car loom has 2 gold terminals and 2 silver terminals. The gold and silver terminals have different resistance. The gold is also less suspectable to corrosion. You'll also need to connect the wires with will also add resistance. The resistance will effect the readings.
Cheers for the suggestion though!
I've sourced plenty of gold terminals now. I might put little kits together so people can easily replace theirs.
Old Jan 31, 2025 | 08:39 PM
RA122125's Avatar
Banned
What I linked are used at the LR repair shops in my area for that job, no known issues. I also repaired my personal 04 D2 with these 3 years ago, been working perfectly and within specs. It's often hard for folks to do that type of terminal repair without the proper crimpers, and those can be expensive for a one time repair. Easier to do a wire splice for most folks
Old Feb 1, 2025 | 02:40 AM
Bone9's Avatar
That's fair enough. I just like to do a proper job.
flybd5
LR2
31
Mar 30, 2024 09:58 PM
Frank4
Mar 10, 2023 06:15 PM
RA122125
Sep 14, 2021 09:45 AM
shanechevelle
Aug 14, 2018 06:33 AM
csp
Jul 18, 2013 05:18 PM
