O2 sensor question
Thats one of them tools that are nice to have but arent really neccasary in my opinion. You can usually pick them up at about any parts stores or tool places. I usually use an open end wrench unless its seized up real bad then i just cut the wire and use a regular socket......just my $.02
The OEM brand O2 socket is $9.99 at Autozone. You can also rent one for free when returned to AutoZone. The tool is only really required for the front drivers side. The bend of the exhaust pipe and tight space make it nearly impossible reach with a opened ended wrench. I found its easiest to unplug the wire before removing each sensor.
