O2 sensor question
Old Nov 26, 2018 | 01:44 PM
Wesley Lueders's Avatar
Default O2 sensor question
I'm chasing a couple of codes regarding the O2 sensors. The descriptions are:
Lambda sensor aging tv bank 2
Drive cycle C
Lambda sensor aging tp bank 2
Drive cycle C
So from my research, this means they are basically slow to respond, am I correct in this mode of thought? Does "tv" and "tp" refer to position, as in upstream and downstream, or something different?
Thanks for any wisdom provided,
Wesley
Old Nov 26, 2018 | 01:56 PM
redwhitekat's Avatar
Most times it's not the o2 but vaccum leaks fuel purge valve bad exhaust leaks
perform a smoke test and get a new Hyundai fuel purge valve before you go spending money on o2 sensors
Old Nov 26, 2018 | 02:26 PM
Thanks for the advice! Since it's only on bank 2, I've looked and listened for exhaust leaks on that bank, with nothing found. If it were a part of the EVAP system, wouldn't I have those codes on both banks?
Plus, does any one know what the "tv" and "tp" refer to? I can graph the sensors with my scanner tool to verify, but I'm really curious as to what those two designations mean.
Thanks again for all the wisdom!
Wesley
Old Nov 26, 2018 | 06:07 PM
Well you can buy the o2 sensor cheapest place is rock auto however I still strongly advise what I said above. Smoke test the vaccum system and exhaust and replace your fuel purge valve. All cheap solutions
Old Nov 26, 2018 | 06:08 PM
The fuel purge valve will effect everything.
Old Nov 26, 2018 | 07:38 PM
Extinct's Avatar
Read this: https://landroverforums.com/forum/di...e3/#post671009
Old Nov 27, 2018 | 01:35 AM
Frtpilot's Avatar
Purge valve...everything from o2 sensor codes, vacuum leaks (massive and small), misfires, etc. Dorman purge valve #911-800 or a Hyundai purge valve.
Old Nov 27, 2018 | 09:28 AM
redrover75's Avatar
I have been chasing a similar issue. I have replaced the Hyundai purge valve a few months ago, i know it could still be bad.
I sprayed carb cleaner all over, the junctions, seals, etc, no movement.
My codes are P0101, P0172, P0175
Will try to find someone to do a smoke test, there are instructions for a home version, but at this point for the money I would rather have it done.
Old Nov 27, 2018 | 11:16 AM
Frtpilot's Avatar
Check mass airflow sensor (do not spray with contact cleaner, use mass airflow sensor cleaner). Then check coolant temp sender, and check to see if thermostat is stuck open. Your issues sound like MAF sensor issues, but can sometimes be mid-diagnosed and related to cooling system.
Old Nov 28, 2018 | 05:32 AM
redrover75's Avatar
Default Maf
thanks for response, I have cleaned the maf, no luck. I have ordered a new MAF this week, Bosch, will see if that's my fix.
the o2 sensors appear to work by all verything I can read.
