o2 sensors
Old Nov 10, 2012 | 11:46 AM
jeffh's Avatar
Default o2 sensors
So I finally threw a sensor code... was wondering the views on what I see as the 3 main options.
Bosch
Walker
NGK
figure since I threw the upstream passenger side I would just go and do all 4. at the same time. Just curious on your thoughts on these manufactures.
thanks
Old Nov 10, 2012 | 12:16 PM
agthird's Avatar
I have used bosh with no problems, Check amazon for cheap prices...
Old Nov 10, 2012 | 12:21 PM
mx468's Avatar
Use the factory Bosch, I've used other brands before and found the Bosch worked the best for me. Here's a link to them on amazon.
Amazon.com: Bosch 15175 Oxygen Sensor, OE Type Fitment: Automotive Amazon.com: Bosch 15175 Oxygen Sensor, OE Type Fitment: Automotive
Old Nov 10, 2012 | 01:18 PM
Any major brand name, they are all built to the same specs.
Just do not buy the universal 02's with no plugs, and yes Amazon will get you the better prices.
How many miles on your truck and are you re[lacing them all?
Old Nov 10, 2012 | 02:26 PM
Discosomewhat's Avatar
Bosch has been good for me. I don't see why you would do the post-cat sensors because those are just pass/fail for the emissions system; the upstream sensors are the only ones that affect the A/F ratio when running closed loop.
Old Nov 10, 2012 | 02:32 PM
jeffh's Avatar
Mike that is what I thought, but wanted to see what people have to say about different brands and yes I am going to replace all 4...mileage is 121k. added in that I am up for annual inspection.
Old Nov 10, 2012 | 03:00 PM
Dont bother replacing the rears unless you have codes for them, they do nothing other than monitor the cat's.
Save your money for something else.
No it wont hurt to replace them, but if they are not bad why bother?
Just do the front two.
Old Nov 10, 2012 | 03:03 PM
jafir's Avatar
Replacing the rears could possibly even cause headaches later. A lot of o2 senders start reading lean over time, so they might not detect a failing cat as easily. If you replace them with new, you might find out you need cats too.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
Corsair33
Sep 18, 2006 10:15 PM
riebs
Aug 21, 2006 11:48 AM
JRdisco1
Aug 9, 2005 03:33 PM
