O2 Wire harness
Old Jun 11, 2014 | 07:35 AM
NoBama316's Avatar
Default O2 Wire harness
I have read that there was some "Issues" with some O2 sensor wiring harnesses. Well I had code P0150 and put in a new OE O2 sensor and am still getting it, so I assume I have a crack or bad wire in the harness. Is there a certain spot where they are known to go bad? Looks like fun trying to trace it down. Mine is a 2000 SD
Thanks
Old Jun 11, 2014 | 10:01 AM
BackInA88's Avatar
I've head about them getting covered in oil from leaks and having problems.
Old Jun 11, 2014 | 10:35 AM
NoBama316's Avatar
Mine was not covered in oil, the connections were very clean to begin with and I cleaned the harness connector before putting the new O2 sensor on. I get 0.00 Volts showing on my scanner from the new sensor, just like the old, so I assume there is a broken wire in the harness leading back to the ECU, because there is power at the connector.
Old Jun 11, 2014 | 03:55 PM
NoBama316's Avatar
I'm getting .44 volts at the blue wire in the harness from the ecu, 0 at the red with black and 12.3 at the other 2 wires if that helps...I guess the red is the signal back to the ecu? Still 0 on my scanner.
Old Jun 12, 2014 | 07:20 AM
drowssap's Avatar
have you driven the truck more than 50 miles since you replaced them?
Old Jun 12, 2014 | 10:04 AM
NoBama316's Avatar
Yes, and live data with a $4k scanner shows 0.0 volts from the new sensor. I guess I could have gotten a "bad" brand new OE sensor, but I would doubt it.
Anyone else have this issue?
Old Jun 12, 2014 | 10:13 AM
drowssap's Avatar
do not rule out a bad 02, have you tried changing them from right to left to see if the problem follows?
Old Jun 12, 2014 | 10:22 AM
NoBama316's Avatar
Not yet, I am going to get another new one today and install tomorrow when I have a chance.
Old Jun 12, 2014 | 07:22 PM
NoBama316's Avatar
*Update*
Just like in WW2, the Germans failed again, this time with the replacement O2 sensor. Just installed my 2nd new sensor and I'm getting live readings now. All seems well again.
Thanks.
theswede
Oct 29, 2015 01:05 AM
charcoal grey
Apr 7, 2009 02:10 PM
zracin
Sep 22, 2008 07:18 PM
agarabaghi
Aug 19, 2005 09:03 PM
