oba question
Old Mar 28, 2009 | 06:07 PM
DiscoIIRoop's Avatar
Default oba question
I'm buying the 2inch lift from rovertym. I have an 01 se7 so ill be replacing the rear air bags. My question, maybe a dumb one, is would it be possible to turn the compressor for the air bags into an on board air set up.
Old Mar 28, 2009 | 06:42 PM
Nope, it won't handle the load.
Why are you wanting to get rid of the SLS?
Old Mar 28, 2009 | 07:40 PM
I have been told that it is not very durable even for light off roading. plus i have a leak, every time i go out to get in the truck the body is sitting on the tires. it does fill up as i drive though. is there a better suggestion than converting to the 2 inch springs?
Old Mar 28, 2009 | 08:49 PM
IDAHODISCO's Avatar
No if you keep your bags you just have to replace them every 60,000-100000 to be sure!
I had both air and spring I kinda like my springs ya I have a little bounce but I don't worry about a break down ether!
Old Mar 28, 2009 | 09:21 PM
there would be no way to use the air compressor to fill a tank then use the tank to fill tires or use air tools?
Old Mar 29, 2009 | 09:21 AM
NO way.
colemtd
Mar 30, 2019 08:57 PM
