OBD Codes
Old Apr 13, 2008 | 09:55 PM
yellowlablounge's Avatar
Default OBD Codes
Greetings. I'm new to Land Rovers and new to the site. Bought an '02 Disco II Kalahai about 4 months ago and a '98 Disco I about 2 months ago. The check engine light came on this weekend on the '98 right after I had it serviced at the quick oil change place. I think this is only a coincidence. They have been servicing the '02 since it was new and keep filters on hand for it. It currently has a tank full of mid grade fuel and has been running fine on it. I stopped by Auto Zone today to get the codes and it has a P0316. They also told me it said need plugs and wires. Any help with this code? I did put a bottle of Chevron Techron in today also.
Old Apr 14, 2008 | 09:29 PM
wooz797's Avatar
Default RE: OBD Codes
engine misfire detected on startup (first 1000 revolutions) certainly an interesting code.
did you have them clear it? may have just been a hiccup
Old Apr 14, 2008 | 10:41 PM
okdiscoguy's Avatar
premium fuel only. Both of the truck.
If you want to do new wires, get the 8MM Magnacor wires. Don't use the OEM Bosch wires. You will be replacing them again within a year.
Old Apr 15, 2008 | 10:48 AM
First start running the good gas, you will pick up nearly a mile per gallon and not carbon up your valve stems, which D1's are know to do.
Also if they are not using a factory filter, a Mobil 1 or a K&N 3001 oil filter, stop using theirs. Cheap oil filters let rovers loose oil trghe oil from the filter and pump giving you dry starts which can really hurt your engine.
Old Apr 15, 2008 | 08:24 PM
I am definitely back on the good gas only. Not sure what filter they used at the oil change but will check on that. It was very odd that the check engine light came on within a mile or so of leaving the oil change place. Could have been a cause ofa cheap filter? The same place changed the oil on the D2 about a month ago and no problems with it. They have been servicing the D2 since it was new. Prior owner was the owner of Skyjacker Suspension here in my hometown. As a result, the D2 has a 2" lift. Check them out at www.skyjacker.com. Thanks for the info.
Old Apr 15, 2008 | 08:26 PM
AutoZone said they could not clear it. I have a customer that has a body shop in town and said to bring it by and he could clear it for me.
Old Apr 15, 2008 | 08:29 PM
Only premium from now on. I am planning on doing the new Magnacor wires and plugs. Champion ok?
Old Apr 15, 2008 | 08:35 PM
DiscoOn22s's Avatar
Bosch Plat Plus 4 work good.
Old Apr 15, 2008 | 08:45 PM
I'll try the Bosch.
johnkbl
May 3, 2010 06:19 PM
alemurill
Jul 9, 2008 10:16 AM
AndyTeez
Sep 2, 2007 10:42 AM
mikedemet
Apr 13, 2006 01:05 AM
miishmiish
Mar 8, 2006 12:31 AM
