OBD port gremlins ..PLEASE HELP.2004 discovery se7
Old Aug 13, 2013 | 04:01 PM
moorebl's Avatar
Default OBD port gremlins ..PLEASE HELP.2004 discovery se7
truck is a 2004 discovery se7 USDM .i have gone to 3 places to get my trucks obd port read because of a check engine light.. no one can connect so i began to investigate. there are 4 wires on my obd connector 2 black 1 light brown and 1 light purple. i didn't trust the connector so i cut some of the loom of to expose the wire . no power with ignition on accesory or with the truck turned on. fuse is good with the power outlet. can someone please lead me into the right direction as to what to do.
Old Aug 13, 2013 | 04:29 PM
Download the RAVE tech manual set, which includes wiring diagrams, fuse layout, etc.
Old Aug 13, 2013 | 07:59 PM
moorebl's Avatar
i also want to add none of the interior light work or the glove box light. but the cig lighter works and the overhead visors work. getting weirder
Old Aug 13, 2013 | 08:24 PM
dgi 07's Avatar
have you checked the fuse?
Old Aug 13, 2013 | 08:29 PM
moorebl's Avatar
yes i have checked all fuses and even replaced the good fuses with new ones that are specific to this location
Old Aug 13, 2013 | 08:44 PM
dgi 07's Avatar
If you can tell you have no power at the harness, I can assume you have a meter of some sort. What you need to do is start looking for a cut harness between the fusebox and the OBD port. Check the ground first though.
Eldonkey
Jun 27, 2013 11:09 PM
dc10freighter
Jun 21, 2007 09:39 AM
dofbft
Oct 20, 2006 02:09 PM
