OBD Port Location?
Old Sep 25, 2007 | 09:34 AM
Mark G's Avatar
Default OBD Port Location?
Was not able to find the OBD Port. I read it should be down by the gas pedal. Did not see. Any suggestions? Also, can you help me with the temp sensor location? Is there more than one?
It's a 98 Discovery I.
Thank you,
Mark G
Old Sep 25, 2007 | 10:01 AM
Default RE: OBD Port Location?
OBD2 port in under the steering column.
Old Sep 25, 2007 | 05:14 PM
okdiscoguy's Avatar
Temp sensor is located just under where your top radiator hose connects. There is the temp sending unit, and the temp switch for the AUX electric fans. You also have a temp sensor for the fuel on the driver's side of the fuel rail, and an air temp sensor on the airbox.
Old Sep 25, 2007 | 10:38 PM
Mark G's Avatar
Thanks guys, I found it. It was really tucked up there. I cleared the temp code and checked the connections on the temp sensor. The gauge seems to be reading more normal, but I'll keep an eye on it.
Mark G
Old Sep 26, 2007 | 06:49 PM
okdiscoguy's Avatar
If you are getting hot, it is not good!!! You can drop a sleeve fast.
Make sure your coolant levels are good and if you are losing any, find out where.
jw928
Dec 31, 2020 12:23 PM
KevinTheCook69
Jul 15, 2012 02:19 PM
jtherien53
Dec 18, 2008 01:22 PM
dc10freighter
Jun 21, 2007 09:39 AM
dofbft
Oct 20, 2006 02:09 PM
