Obd2 not responding with scan gauge
Did you cut away the harness covering on the pass footwell. the OBDII port is fed off header C0286 pin 16. The header is the gray located under the pass footwell the the left of the blower motor.. Check the RAVE for more info.
Here is some info from my experience:
https://landroverforums.com/forum/di...-repair-57435/
https://landroverforums.com/forum/di...il-data-58201/
