OBDII Link Failure
Old Sep 2, 2015 | 10:47 AM
acamato's Avatar
Originally Posted by pacman68
I was wondering about that header C0286. On the outside of the protective covering it looks clean.
How did yours look on the outside vs. once you cut the covering? How did you determine it was the header?
Also, I assume they are connectors or is it something different.
The covering looked clean from the outside, once I cut it open it was nasty.
Old Sep 2, 2015 | 10:50 AM
acamato's Avatar
I opened up the header last night and C0286 visually looks clean. What test should I perform on this header to determine where the fault could be?
I could test for continuity from OBDII port pin 7 to pin C2086 pin 16. From C0286 pin 16 in header meshes with pins 13,14,15,17,18,19,20 on header C0286, which connect to all modules. But what else could I test. Is there a way to test if the ECU is faulty?
I would test for continuity. That will tell you if the port is getting a signal.
Old Sep 2, 2015 | 11:13 AM
pacman68's Avatar
First of all thanks for all you help. Its frustrating when you have to fix something, so you can then determine what you need to fix.
If I determine all ports are getting signal, then what would I check after that. A ground?
I noticed that in the wiring diagram 2 grounds exists, pins 4,5 from DLC connector. They connect to C0551-1 and C0017-5.
C0551-1 per rave looks like it is located under the RH fascia carpet I assume, as it only shows arrow pointing to carpet. Could it possibly be a bad ground there?
Old Sep 8, 2015 | 03:22 PM
pacman68's Avatar
Tested for continuity on header and at connectins. All checked out OK. I assume since I get no volts on Pin 7 that it is shorted to ground somewhere, but upon inspection of K wires do not see anything that seems like they are touching a ground area, so I am at a loss. Very frustrating.
Old Dec 13, 2021 | 10:12 PM
Zdug4x4's Avatar
7th Gear
Did you ever figure it out? I’m at a loss seeing as I have good continuity and different voltage readings from the ecu k lines with the header disconnected. I get Battery voltage from ecm and when that is disconnected from header my scanner will read. But the ecm is really the only one I need to read haha. This is ECM #2 for me and have a 3rd to test but thinking it’s a separate issue and may be related to a ground wire in the header but can’t find any info.
Wayne
Oct 2, 2020 12:10 PM
Oscar G
Aug 20, 2007 05:18 PM
NCdiscoII
Jul 14, 2006 06:21 AM
JRdisco1
Aug 5, 2005 12:25 AM
izzy
Feb 27, 2005 10:43 PM
