..:: The octane situation ::..
Old Sep 13, 2016 | 07:13 AM
adolfojbonilla's Avatar
Default ..:: The octane situation ::..
Hello Roverers!
I would like your input on what type of gas are you fillin' your Discos with (87 or 91), and why are you using it?
The reason I asked is cuz I've always used 87 since I had my 2002 Disco SII, but two fills ago I mistakenly filled the tank with 91, and I felt the truck responding better, so I filled it up again with 91 -yes is a 40 cents difference, but is it worth it at this point in time?
Your feedback will be very much appreciated, thank you all! ;-]#
Old Sep 13, 2016 | 07:26 AM
RedRovin''s Avatar
My gas door says to use premium only (93) and that is what I use. Can't comment on anything else
Old Sep 13, 2016 | 07:42 AM
dgi 07's Avatar
Shell V-Power 93.
Only time I used regular (87) was during Hurricane Sandy when the only thing you could get was regular. Who knows, that stuff was probably 79 but the time everything was said and done.
Old Sep 13, 2016 | 09:52 AM
Alex_M's Avatar
The manual states minimum octane of 92 which is hard to find. I've tried every grade pretty extensively and after all my testing, all I run is 93 octane. Usually Shell if I can fond it, despite the cost difference.
Old Sep 13, 2016 | 12:19 PM
Motorhead1's Avatar
Only Premium like the sticker says...The only time I've had a cylinder miss fire was when I was running cheaper reg unleaded from the only gas station for many miles around, out in the middle of the desert (I had no choice). I also notice a difference in MPG's with premium too.
Old Sep 13, 2016 | 07:28 PM
Frank4's Avatar
Been using non ethanol for the past couple of fill ups. 93 oct. @ $3/gal. Not bad and I picked up 1.5 mpg to a whopping 10.5 mpg!
Old Sep 14, 2016 | 06:58 AM
dgi 07's Avatar
Man, that sucks.
I get 40mpg, rolling downhill in neutral with a tailwind.
Old Sep 14, 2016 | 10:14 AM
Motorhead1's Avatar
Sounds about right!!!! hahahahaa
Old Sep 14, 2016 | 01:25 PM
Frank4's Avatar
Originally Posted by dgi 07
Man, that sucks.
I know man, I know. I think mine could break the high teens mpg, if it was falling off a cliff. The guys claiming high teens and 20's mpg!? Come on man!!! I am sure one will chime in here shortly with tales of a cross country drive and 21mpg.
Old Sep 14, 2016 | 02:36 PM
mollusc's Avatar
I keep records for all my vehicles using fuelly.com
I'm currently at 11.6mpg overall on the D2, but that's with only a dozen fills since I've owned it. The lowest I've recorded since doing the head gaskets is 10.7; highest is 14.3. I used regular octane once before doing the gaskets and it ran like crap. Threw some Seafoam in the tank to make it a bit happier and have only used Premium since then.
I offset this with a 40+mpg bike and my wife's 65mpg Vespa...
