Odd brake pedal feel
Hi guys. I noticed that when first braking the pedal feel is firm, but does go down quite a bit. I then noticed that if I start braking, then let go of the brake and apply again immediately (pump the brake pedal once) the pedal feel is really firm with almost no travel and the brakes apply very hard. Is this normal? I've changed the brake fluid and bled the system with the same result. Anyone else notice this. The truck is new to me so I'm unfamiliar with the brakes acting any differently and I haven't driven any other Discos.
Please read the following thread for more info about doing the job without a scanner: https://landroverforums.com/forum/di...very-ii-59654/ - Note, Disco Mike mentions that it can take up to 7 bleeds to get all the air out.
My vote is check valve or entire booster itself.
Napa has the check valve, I believe the part number is 89000.
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
So I took the vacuum line out of the intake and blew into it, no air went in (which is good from what I read). I then tried to suck air out of it and wasn't able to draw any air out (which I read that I should have been able to if the check valve was working properly). I took the valve out which released audible vacuum. I sprayed a bit of electronics cleaner into the valve (the only spray handy that would dry quickly) and I then was able to blow air into the valve. I tried again at the other end of the vacuum line and was able to draw air out. I'll drive it today and see how it goes. The check valve was impossible to pull out of the vacuum line, so I'm not sure how to remove it in case I need to change it out.
I read on some Subaru forums that people clean and lubricate them with WD40. I guess there is a Subaru out there that has these seize up on them frequently. I think I'd rather just replace the part since it's not expensive. My question is if anyone has had any luck removing this thing from the vacuum line. I can turn it and have tried pulling it out with no luck. I don't want to risk breaking the line. I'm considering cutting it just below the valve since there would still be plenty of line to attach a new one to without pulling on it when installed in the booster.
I did flush everything, but ended up with the same pedal feel. I hadn't changed the lines yet since it only has 46k miles, but I do forget that it's 10 years old. Perhaps it's time for ss lines.
